Pietenpol-List: Wing Rib - Auto Cad - Careful what you get
Pietenpol-List: Re: Wing Rib - Auto Cad - Careful what you get
Original Posted By: Bill Talbert
I noticed this, too. Does anyone have a more accurate one? Also, what is the status of whether or not we can make CAD drawings of the whole plans? > THIS IS JUST A QUICK NOTE ->> > Last month there was an AutoCad drawing of the wing rib put out> on this usenet and I have found it to be not per the pietenpol> prints which are given by Don Pietenpol. Some of the discrepancies> are:> > 1. Spacing between front and rear spar was not 27-3/4 inches.> I found it to be about 28-1/4.> 2. The last brace at the trailing edge was not from the upper> side of the rear spar to the lower capstrip at the trailing> edge. This is weaker support for the Aerodynamic forces if> it is backwards from the print.> > I did not check any further. > > I guess the term Caveat de-Emptor has a familiar tune. > > > > --> -----------------------------http://www.wrld.com/w3builderPietenpols, Electronic Music,Website Design, Stompilation________________________________________________________________________________
THIS IS JUST A QUICK NOTE ->Last month there was an AutoCad drawing of the wing rib put outon this usenet and I have found it to be not per the pietenpolprints which are given by Don Pietenpol. Some of the discrepanciesare: 1. Spacing between front and rear spar was not 27-3/4 inches. I found it to be about 28-1/4. 2. The last brace at the trailing edge was not from the upper side of the rear spar to the lower capstrip at the trailing edge. This is weaker support for the Aerodynamic forces if it is backwards from the print.I did not check any further. I guess the term Caveat de-Emptor has a familiar tune. --________________________________________________________________________________
