Original Posted By: Prange Larry J PSNS
Subject: Pietenpol-List: Bolts>>Alright, does anyone have a good (ie inexpensive) source for A/C bolts,>nuts, washers and other hardware? I priced up an order to Wicks last night>and it came in at almost $200! Granted, it does include all those big>engine and LG mounting bolts. Aircraft Spruce was about the same.>>Thanks,>>Ken Beanlands B.Eng (Aerospace)>Calgary, Alberta, Canada>Christavia MK 1 C-GREN>>>________________________________________________________________________________
Original Posted By: Don Mosher
Re: Pietenpol-List: Bolts
Ken,Try Dillsburg Aeroplane Works. They have tubing, hardware, etc. All thenitty gritty to build a plane.they will probably beat anyone on hardware and 4130.Call them for their price list.717-432-4589 (PA.)walt-----------------------------------------------------Click here for Free Video!!http://www.gohip.com/freevideo/-----Original Message-----
Original Posted By: cat_designs(at)juno.com
Just received the latest issue of To Fly with a flyer for the SAA GatheringJune 13-14-15 at Urbana Illinois.First on the list of forums is the Pietenpol forum Friday morning by LarryWilliams, I assume our own Piet list Larry Williams.At this point the weather doesn't look VFR from Atlanta anyway the Skyhawkwill still be in annual, so I'll be driving. Looking forward to seeinglister's and all other Pietenpol people there.Skip in Atlanta, Map Quest says 10.5 hours from Urbana.________________________________________________________________________________Date: Fri, 6 Jun 2003 14:46:37 GMTSubject: Pietenpol-List: Bolts
Subject: Pietenpol-List: Rudder PedalsI am in the process of installing the rudder pedal in the front cockpit. On the plans they are tilted towards the back of the plane(if you aresitting in the front seat the tops are tilted towards you when the rudderis centered). I was testing them out before I drilled the holes and theyseemed to be awkward to use. Has anyone on the list used the front seatruder pedals while flying and do you have an opinion on the way they feelwhen flying? I think they would be better if they were vertical or slantedaway from you. Does this make any sense it's still early out here inCalifornia and I was up late building.Corky what does your Test Pilot think of them?Chris Sacramento, CAThe best thing to hit the internet in years - Juno SpeedBand!Surf the web up to FIVE TIMES FASTER!The best thing to hit the internet in years - Juno SpeedBand!Surf the web up to FIVE TIMES FASTER!________________________________________________________________________________Date: Fri, 6 Jun 2003 20:15:51 GMTSubject: Re: Pietenpol-List: Bolts
If one parts being held with the bolt rotates then it needs to be fastenedwith a drilled bolt shank and castle nut and a cotter pin or safety wire.If the pieces are being held together do not rotate, then a nylon lock nutis sufficient (firewall forward excluded in some cases)DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper----- Original Message -----
Original Posted By: Mike
Hey allCheck out the nice Model A engine in June, Sport Aviation Pg 68. Anybody knowwhat that costs?Dick________________________________________________________________________________Date: Fri, 06 Jun 2003 11:28:09 -0700Subject: Re: Pietenpol-List: Bolts
I should have been more clear.... I meant safety wire in a drilled bolt head toprevent rotation.... thanks for the clarification
