Pietenpol-List: Replicraft
Re: Pietenpol-List: Replicraft
Subject: Re: Pietenpol-List: ReplicraftGreetings:Give them a call. I dealt with Steve and he did a great job. He was prompt to answer my e-mails and phone calls. The work on what I bought was very good.Joe MatthewsColumbus, GA________________________________________________________________________________
Original Posted By: "Gene & Karen Rambo"
Subject: Re: Pietenpol-List: ReplicraftRichard, We took a few days off to construct and move the office, and to enlarge the wood shop. The phone lines are now up and running...and I'm wading through the e-mails as fast as I can!!!Sorry for the delay in answering.Regards,SteveReplicraft Aviation________________________________________________________________________________
Original Posted By: Flite407(at)aol.com
replicraft is alive and well. I do not know why you have not received aresponse . . . you might try another e-mail________________________________________________________________________________
Subject: Re: Pietenpol-List: ReplicraftRichard It took me two tries to get a catolog, and I did get oneGary________________________________________________________________________________
Subject: Re: Pietenpol-List: ReplicraftIn a message dated 8/2/00 11:33:43 AM Central Daylight Time, aircamper(at)yahoo.com writes:>I talked with Vi Kapler at Broadhead, and he is getting together with someone to cut all the metal parts, using either laser, or water (I forget which). Vi also did a question and answer session, when he told of some of his experiences while working with Bernard Pietenpol. He worked with Bernard for some ten years, and said it was the best ten years of his life.VITALIS KAPLER1033 Forest Hill Dr. SWRochester, MN 55902Te. 507-288-3322________________________________________________________________________________Date: Thu, 03 Aug 2000 07:11:45 -0600
Original Posted By: "Ignitor"
Subject: Pietenpol-List: ReplicraftAnyone using Replicraft should be aware that he uses the 1929 plans. Ibought a set of eng. mounts for the Ford A and just like everything elseon the Piet plans, they are built wrong. Not the fault of Steve atReplicraft, He was just building to the plans. The 29 plans show a 2 1/2in. drop in the motor mount. The 33 plans show 1 in. drop. The 1 indrop comes out to about 2 1/2 degree. I think someone got there unit ofmeasurements mixed up. If you drop the Ford 2 1/2 in at the nose alongwith a 72" prop, you are looking at a prop strike. None of the picturesof early Piet's appear to have more engine drop than later built Piets.Leon S. looking at a box of "to the plans" left over parts.________________________________________________________________________________
Does anyone know if Replicraft is still in business? They moved toFlorida. I called their website telephone numbers, but both have beendisconnected. We're trying to locate 4130 steel fittings for GN1 wingstruts. Thanks, Jim Cooper________________________________________________________________________________
