Original Posted By: Wizzard187(at)aol.com
Mr. Pietenpol My system was wiped out and if you have sent me a reply I did'nt getit. Could you send it again?Thank YouGary BellMr. Pietenpol I ordered a set of plans from you last year. I received aconstruction booklet, drawings for the 3 piece wing, Corvair enginemount and prop hub, extended fuselage and the orignal drawings. I wouldlike to know if there is any drawings or information other than what isin the construction manual on Corvair engines. For exampel how to buildthe intake manifold or the the cooling system with the blower fanengine. I talked to Mr Vi kapler and he told me to give you a call. Myfuselage is almost complete on the landing gear with the tail fethersbolted on. So it is almost time to start the engine mount ant the firewall foward stuff.Thank You for your helpGary BellPietenpol Builder________________________________________________________________________________
