corvaircraft: [Fwd: [Q-LIST] William Wynne and James Gundi]
Subject: corvaircraft: [Fwd: [Q-LIST] William Wynne and James Gundi]===============================CorvAIRCRAFT===============================>From rec.aviation.homebuilt newsgroup:Those of you who are aware of the Piet accidentin Florida, and the heroics following, will be pleasedto know that both are off the critical list. Betsy hasjust come from the hospital, & both are with friends andfamily and doing as well as can be expected.William has just had a [first] set of skin grafts. Unfortunately,the healing process requires that both be VERY immobile fora period of time. Anything that friends could send; cards,anything audio, bright colors, etc. would be useful and important.Things to occupy the mind of an immobilized patient.Flowers are forbidden because of the risk of infection, and balloonsmust be of the mylar type. I would guess that plastic items are ok,stuffed animals probably not as there is risk of infection.They are in beds C604(James) and C606 (William)in the ICU/Burn Unit at Tampa General Hospital.Davis IslandsPO Box 1289Tampa, Florida 33601Hospital phone (patient representation) (813)251-7249===============================CorvAIRCRAFT=============================== To unsubscribe send "unsubscribe corvaircraft" to"majordomo(at)usm.edu" For help send "info corvaircraft" or "help" to "majordomo(at)usm.edu"________________________________________________________________________________
