Pietenpol-List: bellcrank spring
Re: Pietenpol-List: bellcrank spring
Subject: Re: Pietenpol-List: bellcrank springIn a message dated 9/12/01 8:26:35 PM Pacific Daylight Time, javcr(at)yahoo.com writes:> About the Piet, i have been reading the Pietenpol> manual, it call for a spring on the bellcrank and make> the center struts 4" longer, someone of you have> experience with this?> Making the center struts sounds good for me, so the> access to the cockpit will be more easy, but have no> idea of the spring on the bellcrank.> Thanks for your comments.> Javier Cruz> Javier,On the last two airplanes built by BHP (which were Corvair powered), he installed a screen door spring from the top of the elevator bellcrank to the lower part of the pilot seat back. The spring had enough tension to hold the elevator straight with the horizontal with the airplane at rest. He tried this because the elevator is not aerodynamically balanced. I believe that I heard from Vi Kapler that the experiment works. I do not know how many Piets today have this installation. Doug Bryant________________________________________________________________________________
RE: Pietenpol-List: bellcrank spring
I have installed a spring-type trim system in my Piet, similar to the designthe Mike Cuy developed. It appears to work well in my basement, butobviously has not been flight tested. Mike has been flying his for severalyears now. I can't imagine not having a trim system in any airplane. Ifanyone wants to see pictures of my installation, let me know and I wille-mail them privately (not on the list)Jack Phillips-----Original Message-----
Original Posted By: "Ignitor"@matronics.com
Subject: Re: Pietenpol-List: bellcrank springIn a message dated 9/13/01 9:54:05 AM Pacific Daylight Time, Doug413(at)aol.com writes:> About the Piet, i have been reading the Pietenpol> > manual, it call for a spring on the bellcrank and make> > the center struts 4" longer, someone of you have> > experience with this?> > Making the center struts sounds good for me, so the> > access to the cockpit will be more easy, but have no> > idea of the spring on the bellcrank.> > Thanks for your comments.> > Javier Cruz> > > > Javier,> > On the last two airplanes built by BHP (which were Corvair powered), he > installed a screen door spring from the top of the elevator bellcrank to > the > lower part of the pilot seat back. The spring had enough tension to hold > the > elevator straight with the horizontal with the airplane at rest. He tried > this because the elevator is not aerodynamically balanced. I believe that > I > heard from Vi Kapler that the experiment works. I do not know how many > Piets > Javier, By the way, this was not a trim system. It was a way to prevent the weight of the elevator from to fall slightly down in flight due to gravity. Doug Bryant________________________________________________________________________________Date: Thu, 13 Sep 2001 20:27:27 -0700
----- Original Message -----
