Pietenpol-List: airspace is opening
GA Allowed to Resume Normal Flight Operations This Morning The following ATCSCC Advisory was issued by the FAA's ATC CommandCenter in Virginia: At 15Z, the NAS will be open to all aircraft including VFR/IFR, GAand commercial operations, regardless of flight purpose. HOWEVER, THE NAS REOPENING DOES NOT INDICATE THAT ANY PARTICULARAIRPORT WILL BE OPEN OR IF OPEN WHAT RESTRICTIONS MAY BE IN PLACE ATTHAT AIRPORT. *** THIS IS UP TO THE DISCRETION OF EACH INDIVIDUAL AIRPORTAUTHORITY AND IS NOT UP THE DISCRETION OF NAS CONTROLLERS.*** This means that as of 10:00 AM central daylight time, generalaviation may resume normal flight operations. Pilots should, however,check with Flight Service to make sure the airport they plan to fly toor out of is open for flight operations. ________________________________________________________________________________Date: Thu, 13 Sep 2001 12:04:57 -0400
Re: Pietenpol-List: airspace is opening
