Mark asked:>Can you tell me, in the views of the cockpit, what are the>two gauges at the bottom of the instrument panel for?Gene replied:>They look like oil pressure and temperature to me. Is that correct?Yep; that's what they are.And then Corky wrote:>installed instruments, connected all dual controls, labeled controls,>installed oxygen system,Whoa, Corky! You plan on cruisin' your Pietenpol up in the flight levels? It's mighty lonely at 12,500 in an open-cockpit airplane doing maybe 75 MPH mixing it up with the heavies up there... ;o) But I do like the weather down your way... "57% humility". Not like Texas (0% humility).Oscar ZunigaMedford, Oregonmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Pietenpol-List: Ernie's panel and stratospheric Corky
Re: Pietenpol-List: Ernie's panel and stratospheric Corky
Subject: Re: Pietenpol-List: Ernie's panel and stratospheric CorkyOscar and ALL Piets,You youngster don't realize that some might need oxy at sea levelCorky in La breathing heavy since Dr. Diddie Dumb Wad refused my medical.________________________________________________________________________________
Original Posted By:> Isablcorky(at)aol.com
Corky,If you are putting O2 in your plane, run a little hose to the carb for thatlittle extra power on take-off's and high speed fly-by's.
(I can see it now, Corky and his 200HP piet doing hammerhead stalls!)Robert HainesMurphysboro, Illinois>____
