Pietenpol-List: Pietenpols in Oklahoma
Kent,Where in Oklahoma are you, I'm in Tulsa. I have my fuselage nearlycompleted. I started my fuselage first, with the thinking that when Igot started on the wings and tail, I would have something to hang themon when done. There are several ongoing Pietenpol projects that I knowof here in Tulsa. Send me an E-MAIL if you wish. By the way gang, thisis my first posting here, been just reading for a while soaking up allthe info. Thanks!!JodyTulsa, Ok.________________________________________________________________________________
Pietenpol-List: Re: Pietenpols in Oklahoma
Jody, I'm in Oklahoma City. Glad to know there are some builders locally,even if an hour or two away. I'm a member of EAA Chapter 24 , but no one isbuilding a Piet. The only other wood aircraft going on here are a couple ofGP-4's, a KR-II, and a Volksplane rebuild. The rest seem to be RV's. I asked about the starting sequence of building as I wanted to startwith something easy (if ribs are easy). I figure I can hang the tail andwings off the wall after they are built, while I start the fuse, unlessbuilders usually find they use leftover wood from the fuse to use in thetail. Is there such a thing as left over spruce? :) Hey, the plans for the ribs show one support against the spar, Ithought wood ribs used a support against the front and back of the spar. Is'support' the right terminology?? Is the fuse recommended first because the tail parts need to be madeto fit the fuse? So many questions, I'll have to search the archives likea wild man. I stayed up till midnight looking at the plans. There seem to beabout 3 separate drawings of the flying struts. ?? Is there anythingmissing on the plans that need to be there? That last statement will leaddown a long path, I'm sure. Need to buy some Kerosene for the garage heater, it got down in the30's here last night! Winter is here at last, after a beautiful fall.Kent________________________________________________________________________________Date: Tue, 27 Nov 2001 09:10:34 -0500
Re: Pietenpol-List: Pietenpols in Oklahoma
Subject: Re: Pietenpol-List: Pietenpols in OklahomaIn a message dated 11/26/01 11:20:34 PM Pacific Standard Time, gbloud(at)msn.com writes:> Kent,> Where in Oklahoma are you, I'm in Tulsa. I have my fuselage nearly> completed. I started my fuselage first, with the thinking that when I> got started on the wings and tail, I would have something to hang them> on when done. There are several ongoing Pietenpol projects that I know> of here in Tulsa. Send me an E-MAIL if you wish. By the way gang, this> is my first posting here, been just reading for a while soaking up all> the info. Thanks!!> Jody> Tulsa, Ok.> Guys,There are quite a few Piets in Wichita also. Doug Bryant ________________________________________________________________________________
Original Posted By: John Myers
Subject: Re: Pietenpol-List: Pietenpols in OklahomaSomewhow I've got a feeling there are none in South Dakota tho.Jerry in South DakotaSoloed 28 Oct 2001________________________________________________________________________________Date: Tue, 27 Nov 2001 18:23:31 -0600
Original Posted By: JamesJboyer(at)aol.com
Subject: Re: Pietenpol-List: Pietenpols in OklahomaIn a message dated 11/27/01 7:21:36 PM Eastern Standard Time, Jfelts101(at)aol.com writes:>Soloed a Piet ? If so WOoooHoooOO!! Great for you !________________________________________________________________________________
Subject: Re: Pietenpol-List: Pietenpols in OklahomaIn a message dated 11/27/2001 4:21:36 PM Pacific Standard Time, Jfelts101(at)aol.com writes:> Somewhow I've got a feeling there are none in South Dakota tho.Hi Jerry, I'm originally from Watertown. My Piet progress is fuselage 80% done (90%) to go as you will find out, ribs all done, tail surfaces all done. and stell fittings in progress.My goal is to fly it back to Watertown to see my brother and talk him into going to Brodhead with me.Go luck building a Piet; you will have a lot of fun and time passes sooooo fast!Cheers, Jim________________________________________________________________________________Date: Tue, 27 Nov 2001 23:27:59 -0800
Original Posted By: "Ed Grentzer"
Subject: Re: Pietenpol-List: Pietenpols in OklahomaWish it had been a Piet I soloed in that would have been soooo cool. I soloed in a Fightstar IIJerry in South DakotaSoloed 28 Oct 2001________________________________________________________________________________
