Pietenpol-List: 0-200 mounts
Mike,I have an 0-200 for my Piet. My Piet is the normal length for a Model A.Is yours the longer fuselage? Is your motor mount different from the one inthe "improved" plans?Thanks,Ted BrousseauNaples, FL----- Original Message -----
Re: Pietenpol-List: 0-200 mounts
Original Posted By: "Lou Larsen"
Mike, I have an 0-200 for my Piet. My Piet is the normal length for a ModelA. Is yours the longer fuselage? Is your motor mount different from theone in the "improved" plans? Thanks, Ted Brousseau Naples, FL== Hi Ted; MY Piet is the long fuselage. Had an "A" in it for two years, Moretrouble than it was worth. Found a buyer for the same money that the0-200 cost. The mount was made by Chad Willie. Don't know if it the same as theprint, but it works. I am a snow bird in Lake Worth Fl. My Piet is in Saratoga NY. I havebeen to Naples several times. Was out to the airport. There is a Pietout there.I left my card, but the guy never said hello. Mike________________________________________________________________________________
