Original Posted By: "Ian Holland"
Subject: Pietenpol-List: Re: Pietenpol-List-corvairIn a message dated 1/31/2002 2:10:02 PM Eastern Standard Time, kengg(at)texas.net writes:> How much did you pay?> > I've found a running 65 in an automatic convertible, but he wants $450 for> it.> > Would I be better off buying one for $150 or $200 that doesn't run, since> I'll be rebuilding it anyway?> > ThanksI rebuilt a corvair using WW manual. I did not finish it and ended up selling it in my divorce. I replaced almost everything. The cylinders and pistons are good for core value. The only thing I used was the cam, crank and block. I bought heads seperately and had a valve job done on the best pair I could find ( I had about 6 seperate heads, about $20 apiece.). I bought two engines for $150.William Koucky________________________________________________________________________________
