Pietenpol-List: Pietenpol engine choices.
Re: Pietenpol-List: Pietenpol engine choices.
Original Posted By: "Fisherman Caye"
In the "for what its worth column"there is a piet flying in the USA with adirect drive conversion of a 2.5 "iron duke" 4 cyl gm motor.From posts inthe past it seemed to be doing good.If I remember correctly, the builder cutdown a tree on his farm and sawed up the wood and built the plane from itand then converted the engine also.There is info on it somewhere online.Bill----- Original Message -----
Re: Pietenpol-List: Sports Aviation articles wanted?
If the book is not published, would there be any problem in postingit? Or is it too large. An alternate would be maybe to see if the EAAwould make it available. It seems a shame that a work done by someoneto enhance the experimental part of aviation is not readily available.I purchased the Eric Clutton book, and although well done, it stillleaves some room for guesswork. Two books should be better than onebook, if available.What say?-=Ian=-________________________________________________________________________________Date: Sun, 3 Feb 2002 21:07:45 -0800 (PST)
> Re: Pietenpol-List: 84 in Prop
Re: Pietenpol-List: Re:
