Pietenpol-List: Zinc Chromate Primer
Zinc Chromate primer is sprayed lightly (wet, about 1,000 square feetper gallon) on aluminum and steel aircraft parts. It is the best,time-proven primer to prevent corrosion and rust in all applications.Available in green and yellow colors, it also provides maximum adhesionfor subsequent paints.Zinc Chromate primer is also made in epoxy form for use on steel tubeairframes that will be covered with fabric.Gene VickeryTehachapi, CA________________________________________________________________________________
Original Posted By: clif
RE: Pietenpol-List: Zinc Chromate Primer
I have read that Alkyd Enamel paint is dope proof. Chris Bobka-----Original Message-----
Re: Pietenpol-List: Zinc Chromate Primer
Subject: Re: Pietenpol-List: Zinc Chromate PrimerIn a message dated 2/10/02 7:40:10 PM Pacific Standard Time, bobka(at)charter.net writes:> I have read that Alkyd Enamel paint is dope proof. > > Chris Bobka> > Chris, I use ACE oil based spar varnish (not polyurathane) with excellent results. Doug Bryant ________________________________________________________________________________
Home depot was closing out their Behr brand alkyd enamal and I bought about12 quart cans in grey and white. Still need to do a test.Chris-----Original Message-----
