Pietenpol-List: stick with the list guys
Original Posted By: "Sam Marinucci"
Well said, Mike I'm in the process of building my controls(torque tube sticks etc.) I have some 2" plastic pullys from Wicks.Should a 1/4 " washer be put inside the bracket on each side of thepully or should the sides of the brackets be agaist the pully bearing.Thanks for helping Mark ( only 100mi. from Corky) in windy Mt.Pleasant Tx________________________________________________________________________________
Re: Pietenpol-List: stick with the list guys
Subject: Re: Pietenpol-List: stick with the list guysIn a message dated 3/9/02 12:48:35 PM Pacific Standard Time, markmc(at)bluebonnet.net writes:> Well said, Mike I'm in the process of building my controls> (torque tube sticks etc.) I have some 2" plastic pullys from Wicks.> Should a 1/4 " washer be put inside the bracket on each side of the> pully or should the sides of the brackets be agaist the pully bearing.> Thanks for helping Mark ( only 100mi. from Corky) in windy Mt.> Pleasant Tx> > > Mark,Pulleys can be ganged bearing to bearing, bearing to bracket without any washers. This configuration becomes part of the cable jump protection for these two pulleys. Doug Bryant ________________________________________________________________________________Date: Sun, 10 Mar 2002 07:57:55 -0600
