"Dennis the Menace" and others,Originally, my Piet had an empty weight of 645 lbs. with aContinental A 65 - 8 engine, a wooden propeller, Grade A cotton cover with a hand-rubbed doped finish, a Scott 6" tail-wheel, cowling of 0.032" aluminum (NO FIBREGLAS), no upholstery (just a couple of lightweight seat cushions), ASI, altimeter, tachometer, ball slip-skid indicator, oil pressure gauge and oil temperature gauge.Some 14 years later, the cotton fabric strength had diminshedmarkedly (as cotton was prone to do) and I wanted to checkthe structure, so it was stripped and gone over thoroughly with the intention of removing even more weight, if possible.A C85 - 8 engine was installed which added a few pounds over the C65 - 8 and the only places I could save weight werein the fabric cover and the tailwheel. Polyester fabric was sub-stituted for the Grade A cotton and a minimum of dope was used to provide a "serviceable" light plane finish (the originalwas similar to the finish applied to the old Beechcraft Stagger-wing biplanes!). A very light 3" caster wheel with its forks and horn made from 1/8" 4130 steel, welded together, took the placeof the heavy Scott assembly. (BHP used a similar small, light tailwheel on his last airplanes which was non-steerable---andthis inspired me, although mine is steerable via 3/32" cablesfrom the rudder pedals.)Afterward, we weighed it and the dry empty weight was 630 lbs.Since then, I have had custom seat and back cushions made,but they are extremely light in weight. I would guess about 4 Lbs.I believe I could save even more weight by using, say, 2.6 oz. fabric with a fine weave. The polyester fabric I used is too heavyat about 3.6 oz. and has a relatively coarse weave, requiringmore dope. It is so strong that I likely would never have to replaceit due to strength loss, but after over 17 years since recover I would like to check the structure. Grade A cotton used to be the standard for aircraft fabric, but was heavier than the syntheticsand deteriorated much more quickly.If I were to build another Pietenpol, I could save even more weight,but I doubt I could beat Brian Kenney's CF-AUK which has an EWsignificantly under 600 lbs.!Graham Hansen (Pietenpol CF-AUN)Alberta, Canada________________________________________________________________________________
Re: Pietenpol-List: Pietenpol lift struts and center section geometry...and
Oh yes, I forgot the compass in the equipment list I pro-vided in the previous post.If you can find one, use the smaller 2 1/4" dia. compassinstead of the 3 1/8" one. Saves ounces.Graham Hansen (CF-AUN)________________________________________________________________________________
Original Posted By: "LAWRENCE WILLIAMS"
Subject: Re: Pietenpol-List: Pietenpol lift struts and center section geometry...andw...Graham,Read this weight message and felt I'd like to comment. I weighed my airplane yesterday. With wings off, feathers off I weighed all parts to include instruments, venturis, oxy equipment, everything except Engine cowling and cover and the weight is an amazing 504 lbs. I can't believe that cowling and cover will weigh near a hundred pounds. I must have a set of buying scales however I've checked my weight on them against others scales and I'm satisfied they are correct.Corky in La________________________________________________________________________________
RE: Pietenpol-List: Pietenpol lift struts and center section geometry...and
Hi Corky,Depending one the weight of fabric and what kind of finish you put on it, Iwould estimate the weight of cover using PolyFiber 1.7 oz. fabric and theirfinishing system to be somewhere around 30 lbs. Your cowling will probablyweigh around 10 lbs. At most you're going to add maybe 50 lbs with cowlingand cover to bring you up to 554 lbs. You done good, boy! I've weighedmine as it sits so far and estimated the weight of all the remainingcomponents and I figure mine will come in somewhere right around 630 lbs.Jack -----Original Message-----
Original Posted By: Dmott9(at)aol.com
Subject: Re: Pietenpol-List: Pietenpol lift struts and center section geometry...andw...In a message dated 3/14/02 11:49:39 PM Eastern Standard Time, grhans@cable-lynx.net writes:>Thank you for the reply. Sounds like you've had many years of great flying in your Piet. Would love to see it some day. People like you are a wealth of knowledge and I for one thank you for sticking around on this list to answer mine and others neophyte questions. Your a treasure !-dennis the Menace________________________________________________________________________________
