Pietenpol-List: Powder-coating hollow metal struts, etc.
When you have hollow metal (4130) lift struts that have linseed oil onthe inside for rust prevention, what happens to it, the preservative,if the struts are powder-coated and the ovens are at 400 degrees? Iasked a local shop and they didn't have an answer. The struts are openat both ends.DickG.Ft. Myers, FL________________________________________________________________________________
RE: Pietenpol-List: Leading Edge
Original Posted By: Jack Phillips [mailto:jackphillips(at)earthlink.net]
I think I remember that the leading edge sheath wraps around to the bottomon the Grega plans. Do any GN-1 builders want to comment?Gene-----Original Message-----
the GN-1 plans show the L.E. skin wrapping a few inches under the bottom.DJ VeghMesa, AZGN-1 Builderwww.raptoronline.comN74DV-----Original Message-----
Re: Pietenpol-List: Powder-coating hollow metal struts, etc.
Subject: Re: Pietenpol-List: Powder-coating hollow metal struts, etc.
RE: Pietenpol-List: Powder-coating hollow metal struts, etc.
I have not had the opportunity to see an Air Camper in person, but do lovethe airplane for it's simplicity. I would like to build one, but haveconcerns on size. I am 6'1, 190 lbs.Will the standard Pietenpol Air Camper fit, or would it be better tolengthen the fuselage.Thanks for any input.Mark Tracy-----Original Message-----
Subject: Re: Pietenpol-List: Powder-coating hollow metal struts, etc.In a message dated 4/10/02 7:06:26 PM Eastern Daylight Time, mtracy(at)psft.com writes:>Take one of several ways to do this:1. Find a Piet to see in person2. Get the Flying and Glider manual, its got dimensions of cockpit.3. Get someone to send you a snapshot of the cockpit portion of plans. then build up a mockup out of Pine and plywood, and sit in it (dreaming of course) !Lengthening fuselage is not for the purpose of the pilot, but to get the weight and balance correct if you use lighter engine than the Ford Model A. Decide what engine your gonna use, then choosed fuselage length. Most are building the long version, planning on using either Corvair or C85, C90 or something like it for an engine.There is another option for the wing too. One piece or 3 piece.-dennis the menace________________________________________________________________________________
Original Posted By: "hallstenokc"
----- I have not had the opportunity to see an Air Camper in person, but dolove the airplane for it's simplicity. I would like to build one, but have concerns on size. I am 6'1, 190 lbs. Will the standard Pietenpol Air Camper fit, or would it be better to lengthen the fuselage. Thanks for any input. Mark Tracy ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ I am about your size. I built the long fuselage & I have no problem,although I did lower the seat & enlarge the bulkhead cutouts. Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________
Thanks Dale.DickG.----- Original Message -----
Have the shop bake the struts to boil off the preservative oil. Thenpowdercoat after cooling. Then after powdercoating is done, redo the oilpreservative.chris Bobka-----Original Message-----
In case I didn't thank you before, thank you.DickG.----- Original Message -----
Original Posted By: Richard deCosta
Re: Pietenpol-List: A list of fly-ins?
