Pietenpol-List: Control tube ??
Original Posted By: catdesigns(at)juno.com
Hello gang, a couple of days ago, Steven G. Isaacs asked about who made Piet hardware. Vitalis Kapler in Rochester, MN makes hinges and fittings for the tail feathers. He may make more stuff. His # is507-288-3322.Jeff in TX getting back to the fuselageSend and receive Hotmail on your mobile device: http://mobile.msn.com________________________________________________________________________________Date: Thu, 25 Apr 2002 22:15:22 -0700Subject: Pietenpol-List: Control tube ??
-- Pietenpol-List message posted by: catdesigns(at)juno.com Question: Does the metal tabs for the front pulley (the single one in front of the control stick) on the control torque tube get welded to the aileron horn and the tube or are they in front the horn and only welded to the tube? Chris Sacramento, CA Send and receive Hotmail on your mobile device: Click Here________________________________________________________________________________
Original Posted By: "Steven G. Isaacs, MD"
Re: Pietenpol-List: Control tube ??
Original Posted By:n catdesigns(at)juno.com
Chris I welded the tabs to the tube and the horn. They kindof reinforce each otherthat way but if you look closely at the plans , they dont show welds in thatarea?? That pulley bracket's load is doubled because the cable makes almosta 180 degree turn around it so I thought the extra weld area would help. I putthe control stick bushings in first and then had tonotch out the aeirleron horn to get it to slide over them so if you haven't weldedthe bushings in yet do the horn first. Ed Grentzer
