Pietenpol-List: Control cable exits
Heres one I want to throw at you, Im covering the rear fuse area and waswondering on the best way to find the exit holes for my control cables. Theway I came up with was to set the tail up with control surfaces, run thecables out and then mark the area of exit with tape. I then have takenmeasurements for each hole. Does anyone have a better method of doing this?Carl L. trying to eliminate fabric patchingPlease visit my website atwww.megsinet.net/skycarl________________________________________________________________________________
Re: Pietenpol-List: Control cable exits
Carl,That's how I did it. Layed a straight edge over formers to simulate fabricand took measurements from longerons and rear tip of fuse. but I have yetto cut the holes thru.walt----- Original Message -----
