Original Posted By: "Ed Grentzer"
I am going to use an 0-200 on my Piet. I have an 0-200 on my Cessna 140.My Cessna flys 100 mph. Since the Piet will never get close to that speed Ifeel that perhaps a different pitch prop should be used. If I am right, anyideas on how to choose the right propellor?Ted Brousseau________________________________________________________________________________
Pietenpol-List: Size propellor?
Original Posted By: John_Duprey(at)vmed.org
Ted .... I asked Chad Wiley for cruise speeds with an 0-200 before I bought my first set of plans. Chad owns St Criox aircraft and builds and sells wood props. He and his Dad have built several Piets. He owns an 0-200 powered Piet. His answer was " 80 mph solo, 76 mph @ 1250 gross weight with a 76" X 34" climb prop. 80 mph @ gross weight with a 72" X 42" prop but less climb rate. Sounds like a big diffence in props to me but it sounds like he has tried them both. Hope this is of some help. Ed G.>From: "Ted Brousseau" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: Pietenpol-List: Size propellor?>Date: Sun, 16 Jun 2002 23:01:13 -0400>>>I am going to use an 0-200 on my Piet. I have an 0-200 on my Cessna 140.>My Cessna flys 100 mph. Since the Piet will never get close to that speed >I>feel that perhaps a different pitch prop should be used. If I am right, >any>ideas on how to choose the right propellor?>>Ted Brousseau>>MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide ... __________
Re: Pietenpol-List: Size propellor?
----- Original Message -----
Subject: Re: Pietenpol-List: Size propellor?Mike,On this prop business, I have a metal 71/48 which I intend using with my A-65. What do you think I should expect concerning take off, climb and general performance?Would appreciate you commentsCorky in La________________________________________________________________________________
Subject: Re: Pietenpol-List: Size propellor?Thanks Mike,I'll pass this on to my pampered test pilot. It shouldn't be too long now before we can give it a try.Corky in La________________________________________________________________________________
