The father in law of a friend of mine passed away a year or two ago and leftbehind a nearly complete GN-1. It has the fuselage andtailfeathers through silver on Stits Polyfiber P-103 and the wings arecovered through the orange polybrush. An A-65 is mounted and all of thecowling is done except for some riveting. It has the Cub gear withBRAND NEW Cub tires on Cub wheels with Cub brakes. The wing struts are therear Cub struts but need to be sized and finish welded. Prop, tailwheel,instruments, plans, hardware....it is all there. Send emails to Terry (akaJoe) Wakely at twakely(at)rconnect.com It was built in Montana but Joe justtrailered it to Minneapolis area and would probably drive it to you if youwere within a few hundred miles, rather than offload it from the trailer.It has never been certified by FAA but I have been told all the receipts and pictures are there. Therefore the buyer can get the repairman certificate!! Chris Bobka________________________________________________________________________________
