No need to crawl in for you loaded W&B -- a seated pilot's CG is just aboutat your belly-button ( about 9-10" forward of the seat back and 9"-10" abovethe seat bottom) -- a plumb bob & tape measure should give you the distanceto the datum (wing L.E.??) or lay it out on a fuselage side view.Mike C. in KS> As the man said.... It is a good idea to put you in it on another wieghin.> That way we can compute the exact position of the pilot seat. Then putsome> poor soul in the front cockpit and weigh it one more time for the exact> postion of the front cockpit seat. No wiggling or farting so as to put an> error into the calculations.________________________________________________________________________________
