Original Posted By: "DJ Vegh"
Hello, Which size modern streamline tube is the piet comunity using in liew of style 1667 on the Hoopman 33' Prints? Matt________________________________________________________________________________
Pietenpol-List: Streamline Struts
Re: Pietenpol-List: Streamline Struts
I bought extruded aluminum struts from SkyTek. About $900 cheaper than4130 struts and easier to work with.http://www.sky-tek.com/struts.htmlThey are heavy duty.... stonger than they need to be, but inexpensive andthey look great polished!DJ VeghN74DVwww.raptoronline.com----- Original Message -----
Original Posted By: "Dick and Marge Gillespie"
The more common solution, though, is to find old Piper Cub struts and usethe rear struts. These are pretty easy to find and inexpensive because theywere removed for an AD on Cub struts.Gene Rambo________________________________________________________________________________
RE: Pietenpol-List: Streamline Struts
Matt,I will look it up but it will tomarrow before I get back to you.chris bobka-----Original Message-----
