Pietenpol-List: Couple of questions
Original Posted By: "DJ Vegh"
I remember several years back of seeing a 3D drawing of the Aircamper on someone'sweb page. Is that still available? Are most of the Cub style gears fabricatedor are they salvaged Cub gear? What iseach spar length on a 3 piece wing?ThanksLarry Ragan Jacksonville, Fl. lragan(at)hotmail.com ________________________________________________________________________________
Re: Pietenpol-List: Couple of questions
Original Posted By: "Larry Ragan"
I have a 3D rendering of an Air Camper that I drew on my site. I also havethe 3D model file for anyone who wants it. I have cub gear on mine that Iused straight from a 1942 Cub. My spars are a bit over 13 feet long.DJ Veghwww.raptoronline.com----- Original Message -----
Original Posted By: clif
RE: Pietenpol-List: Couple of questions
Hi Larry,You can use a Cub gear on a GN1. Grega put an extra bay in his fuselage sideso a vertical brace and diagonal strut would end up at the same location onthe lower longeron as the aft L/G attach point.The dimension between the front and aft L/G attach points on the Piet is alittle over 28" which is different than that dimension on the Cub L/G.Skip>Are most of the Cub style gears fabricated or are they salvaged Cub gear? >Larry Ragan ________________________________________________________________________________
