Original Posted By: "Shawn Wolk"
I am not planning on using a cowling with the radial. The trick is going to beestimating W-B for building the engine mount with a long fuselage. I did a cardboardmock up of the engine and I think the size will be great. If I decideto build floats, the 100 hp. should do it. I talked with Brian Henneman, the U.S. rep and he offered his help on this. Iwon't be ordering the engine till spring anyway.Dick Navratil________________________________________________________________________________
