Pietenpol-List: front cover snaps
I use snaps on mine, too. One thing I have found is that with the front cover leftoff, I get some of the warm radiator air up my right pantleg. VERY nice onthese cold fall days. I'm experimenting where to put the cardboard radiator blockerso I can channel the most warm air into the front hole.What's that...........you don't have a radiator?Larry________________________________________________________________________________
Re: Pietenpol-List: front cover snaps
Original Posted By: "LAWRENCE WILLIAMS"
----- Original Message -----
Larry,Don't forget the antifreeze!!!! Something we don't worry about.Ted----- Original Message -----
Hey TedYou should think about some anti freeze. It not only increases the boilingpoint of water in the system, it has lubricants for the bushings if you havea water pump and has corrosion inhibitors to protest your radiator whilepreventing scale build up in the radiator tubes.Dick Navratil----- Original Message -----
