Original Posted By: Dennis Engelkenjohn [mailto:wingding(at)usmo.com]
Dennis,It must be a problem with your browser. After the July issue, we startedwith a new way to store the info and it apparently is not working for you.It works for me as I printed out a copy of all the articles so that I cansend out photocopies to those that want it. You really want to make one ofthese blasters guys.I will send out copies with large, readable drawings for an 8.00 taxdeductible donation to EAA CHapter 25. Make the check payable to EAAChapter 25. I will even write the final installment!!!Email me for my mailing address at bobka(at)charter.net.chris bobka-----Original Message-----
Pietenpol-List: RE: Sandblast cabinet
Regarding plans for a sandblasting cabinet, I built a nice one using 1/2"particle board. It really wasn't designed to last forever but it's niceenough. I've used it extensively when restoring my Model A and was able toget large parts in it, like the spoke wheels. I spent maybe $90 includingthe piano hinge and plexiglass. By the way, plexiglass and glass bothbecome opaque after about the same amount of time and I found it easier towork with plexiglass so that's what I used. Also, I eventually bought oneof those $100 pressure pot sandblasters and it works MUCH better than thesiphon type. The Chinese nozzles wear out pretty fast, on both types, soit's important to figure out where you are going to get replacements. In apinch, I had a buddy turn one out of steel, it didn't last much longer. Ijust keep the pressure down to 40psi and that seems to decrease the wear abit.I have plans for the thing including a cutting arrangement for the particleboard on http://roberthaines.tripod.com(I knew drawing those things on CAD would be helpful for someone someday)Robert HainesDu Quoin, Illinois________________________________________________________________________________Date: Mon, 25 Nov 2002 00:49:18 -0800
RE: Pietenpol-List: RE: Sandblast cabinet
Chris,I had the same problem, even using Adobe 5.05. I even tried downloadingand wasn't able to.I did manage to have a look at a few earlier issues, very good copy!!CheersPeter.-----Original Message-----
Sandblast cabinet
Original Posted By: Doc Mosher
Peter,Talk to Dennis E. He apparently figured out how to get it to work.Chris-----Original Message-----
Sandblast cabinet
RE: Pietenpol-List: Do you have a copy of the MacLaren video???
Jim,I think I have a copy of Grant's video. I moved fromDallas to Carrollton and it is one of the unpackedboxes in the garage.I will look for it and if found, you are welcome touse it.Although I had already bought my GN-1 andwas flying it when I learned of the tape, I boughtit to learn more about the basic design.I know the PIET and GN-1 are different but I foundthe tape informative and entertaining.Give me a call anytime at 214 905-9299.Mike KingGN-177MKDallas, Texas-----Original Message-----
Jim,Maybe it is easier for you to get the video from Mike King rather than Greg?Chris-----Original Message-----
