Pietenpol-List: Primer
Subject: Pietenpol-List: PrimerOscar: I don't know how this will work, but the ultra light folks use asqueeze bulb primer. it has a check valve and is under 10 bucks. For theprice, I'm going to order one on my nest AS&S order. If it don't work,I'm not out much. Leon S.________________________________________________________________________________
Re: Pietenpol-List: Primer
Original Posted By: "Leon Stefan"
Leon,,, The bulb type primers are used mostly with carbs that haveenricheners on them such as Bing carbs. They are usually inline on theprimary fuel line and force the fuel into the bowl and enrichener. You mightwant to consider a secondary line that primes the manifold.Carl----- Original Message -----
