Pietenpol-List: wonder how the fisherman is making out
Original Posted By: "TWINBOOM"
Anyone have his web site?waltNX140DL(north N.J.)________________________________________________________________________________
Re: Pietenpol-List: wonder how the fisherman is making out
Walt, Here you go, cayecaulker(at)justice.com , His name is Ray Auxillo btw.Doug BlackburnDoug/Elizabeth BlackburnYucaipa CaliforniaInland Slope Rebels, Riverside Ca. http://inlandsloperebels.com----- Original Message -----
Re: Pietenpol-List: Wood fuse. vs. tube fuse.
Graham,As promised I went to the work shop today on the way to the monthly EAAChapter meeting. I weighed my basic fuselage. It is only the two sidesglued together with the plywood sides and bottom glued on and fire wall inplace. I used the 1/4 inch for the firewall as I did not have the suggested3/16". 1/8" gussets were used through out. 1" sq. longerons and all otherpieces as per plans. All Sitka spruce and birch plywood. I used anaccurate set of scales and with help balanced the fuselage on the scales.It weighs 53 lbs.I am in the process of sanding off all glue drips and runs. I will have towait for it to warm up before doing any more gluing. I am now working onreassembling a Corvair engine and I have a blank glued up to practicecarving out a prop. I built a duplicating machine using a Sears router.Alex Sloan----- Original Message -----
Graham,I failed to mention I am building the stretch fuselage.Alex Sloan----- Original Message -----
Alex,Fifty-three pounds for the basic fuselage frame sounds reasonable.Likely the extended fuselage wouldn't weigh much more than the standard short one because the extra wood doesn't weigh much.A friend here has a standard fuselage complete with turtledeck andside fairing strips. Controls and fittings are removed. I'll see if we can weigh it and give the group some more information.Thanks for the info. I'll see if I can dig up the weights of various Pietenpol components which I have around here somewhere.Graham (Pietenpol CF-AUN in sunny Alberta, Canada)________________________________________________________________________________Date: Sun, 05 Jan 2003 23:30:47 -0700
