Dick,I forgot to mention that you should probably print a copy of what I justsent and keep it around to show the DAR. BTW, I am applying through the EAAto get my DAR so I can inspect everybody's Piets!chris-----Original Message-----
Pietenpol-List: print a copy
RE: Pietenpol-List: print a copy
Kirk,I may need some help from you guys. The DAR application asks forreferrals. I can think of no better group to ask than those that I havebeen helping with book sales, advice, etc. these past few years.I was thinking that if each one of you could send me an email stating waysthat I have helped you through the building process, it may bolster thechances of the DAR going through. It is a tough application. If any of youshould choose to do this, finish it up with your name, N number if you haveone assigned, and your email address. That way I can print them all out andthrow them in with the app to the FAA. Thanks.Chris Bobka-----Original Message-----
Re: Pietenpol-List: print a copy
Thanks all for the responses and especially you Chris for your very completeand documented response. This isn't the first time. I would be very happyto give reference with all of the help you have given me over 3 1/2 years.Dick N.----- Original Message -----
Dick,Please do.Chrisbobka(at)charter.net-----Original Message-----
And don't forget guys that the new DAR for experimental amateur built has nogeographical boundries. Once I get the DAR, I can travel anywhere in theworld to inspect an experimental that is to carry a US registration and I aman airline pilot who gets places cheap, I mean cheap....chris bobka-----Original Message-----
Will do, Chris.I just finished re-making the cooling shroud eyebrows out of steel toreplace my original aluminum ones that mount underneath the middle base nutson the cylinders, per your suggestion. I will send you an email to youraddress with pictures.Jack -----Original Message-----
Jack,I hope it is just the part that goes under the nuts that you remade? Notthe WHOLE eyebrow?chris-----Original Message-----
Yeah, I'm pretty stupid, but not THAT stupid. I meant I remade the brackets(the shrouds are still aluminum - I type faster than I think, sometimes). Ithink I've got all the old correspondence on this subject. I will put ittogether and send it to your e-mail, Chris.Jack -----Original Message-----
