Original Posted By: Richard deCosta
Dear YKW and others, The sport pilot issue will help some of us who can pass a physical butjust can't afford a $125.00 physical. I finally located one 50 miles awaythat does it for $80.00. Thats still 2 much. Anybody know what is theearliest you can arrive and set up camp at Brodhead? Thanks,Bill > Get ready Brodhead, here we come. >>>________________________________________________________________________________Date: Thu, 15 May 2003 15:25:13 -0700 (PDT)
Re: Pietenpol-List: Iron Butt Brousseau
Original Posted By: BFD
BFD,I usually try to arrive on the Wednesday, but that is kind of early, most don't start arriving until Thursday night or Friday morning.Skip in Atlanta----- Original Message -----
Re: Pietenpol-List: prop limits
Subject: Re: Pietenpol-List: prop limitsIn a message dated 5/15/03 5:26:07 PM Central Daylight Time, curiousspider(at)yahoo.com writes:>The optimal prop size depends on how much horsepower you are getting from your engine. The prop that Orin Hoopman drew plans for, dated 3/3/33, was for a 76 X 48 prop. I believe this is the size that B.H.P used on his Model A engines. It's called a 'Paddle Blade Prop', because chord is quite a bit wider at about half way out the blade. These are the plans I used to build the prop for my Model A, but mine was 75" dia. Doug Bryant used a 76 X 48 on his Piet. Stock engine, I would get about 1650 rpm during ground run - up, and unloaded in cruise flight I would get close to 1800 rpm. These are close to the numbers that Doug got. Ken Perkins (Kansas City) thought we were running too much prop for the Model A, and he uses a smaller dia and pitch, but I don't remember what it was. Therefore he would run it at a higher rpm, and take advantage of the higher horsepower above 2000 rpm. His Model A has a pressure oil system, and that is DEFINATELY the way to go. The ol' Model has potential to make good reliable power, but it has to be built to take advantage of this potential...such as pressure oil system, improved induction system, forged pistons, and a better prop flange / hub, to mention a few.Chuck Gantzer________________________________________________________________________________
Original Posted By: "Daniel Bailey"
Subject: Re: Pietenpol-List: prop limitsIn a message dated 5/16/2003 6:42:45 AM Central Standard Time, rambog(at)erols.com writes:> I'd like to hear from everyone> flying a model A and what prop they have.> > Gene> Gene, I'm not flying yet but went through every issue of the BPAN back to 1982 and wrote down every mention of prop dimensions for the Model A. The concensus by far was a 78/42. On the basis of this I ordered that size from Chad Wilie (sp?) and was pleased with the quality. I am turning 1650 static and anticipate 18-1900 in the air. Don Hicks________________________________________________________________________________
