Pietenpol-List: A65 First Engine Run
Original Posted By: "w b evans"
Subject: Pietenpol-List: A65 First Engine RunI did the first engine run on the new engine on Tuesday evening. Fuel on, mags off, pull 4 blades, mags hot, started on the 2nd blade and idled pretty smooth !! Music to my ears !! What a great sound !! Ran for 1/2 hr, not over1100 RPM and shut down for inspection. Fixed a couple of minor oil leaks, anddid the second series of 4 runs with 15 minute cool down periods on Wednesday. All went well. Ground runs complete. Buttoned up everything underthe cowl and installed the cowling and did W&B and Symatry on Friday. Gotta crunchthe numbers & do the paperwork, and a thourough airframe inspection, but it's looking good for first flight on the new engine on Saturday.Chuck GantzerNX770CG________________________________________________________________________________
Re: Pietenpol-List: A65 First Engine Run
Chuck,Good for you! Great feeling isn't it? I have a program for W/B if you'dlike it. Just plug in the numbers and watch the results correctautomatically. Let me know.walt evans----- Original Message -----
Congrats Chuck! And with that N- number, you'll always be "within" theCG!!!!!Ours is about 2 weeks away - mounted the engine today!!!CraigBakeng Duce NX96CW----- Original Message -----
ChuckI'm right there with you. Got her started last weekend. Ran it for aboutan hour. I've got to finish some work on the brakes and it will be time tostart the taxi tests.Dick N.----- Original Message -----
Original Posted By: Stefan Vorkoetter
