Group:I need to decide what mags to use. I have borrowed a set of Scintillas but theyaren't firing.I've pulled this prop till I'm about dead - not even a pop.Is there a supplier of re-built mags out there or do I have to bite the bulletand pay 1200 bucks for new ones.I'm down to just the mags to make this thing run.Thanks;Bert (who's wishing he'd spent the last 8 years working on his golf swing instead)http://bconoly.tripod.com/_____________ ... __________
Pietenpol-List: A-65 magneto questions
Re: Pietenpol-List: A-65 magneto questions
Subject: Re: Pietenpol-List: A-65 magneto questionsBert,What are the model numbers of the bendix mags you have. I might be able to suggest a remedyCorky________________________________________________________________________________
You should have Slick 4333, 4330,4302, Bendix S4-20, S4-200, EisemannLA-4,AM-4 if you have a A-series engine or a C-85 without a starter. Theyhave to be set up for the proper rotation. If you take a mag off a C-85that has a starter, It will not work as it is set up for the oppositerotation. If you have an impulse, it must be wound the proper direction.Cy Galley, TC - Chair, Emergency Aircraft Repair, OshkoshEditor, EAA Safety Programscgalley(at)qcbc.org or experimenter(at)eaa.orgAlways looking for articles for the Experimenter----- Original Message -----
Bert,Try Howard Libersky "Magneto Man" in Okeechobee. His number is863/467-6464. He went over mine and they do good.DickG. in Ft.Myers----- Original Message -----
Original Posted By: Stefan Vorkoetter
Hi BertI had the same problem when I tried starting up. Shoulders hurt for days.When you timed the mags it should have given an indication if there was aconnection for spark. In my case there were two problems, the idler needlevalve on the carb was in way too tight, I installed a primer, and some gum Imissed in cleaning the carb in a small port. Now I am taking it apart againbecause of a sticking float valve in the carb.Dick----- Original Message -----
Original Posted By: Jeff Cours
Re: Pietenpol-List: introduction and -- where's the cargo go?
