Pietenpol-List: Pacific Scientific T5 cable tensiometer
Original Posted By: Carbarvo(at)aol.com
I picked up a used Pacific Scientific cable tensiometer on ebay for $100.These gor for like $800 new. It did not come with risers.I've never used one before and am wondering what number risers are used forwhich size of cable.Also where can I send it for calibration and where would I buy the risersfor it?Anyone have one of these?DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper________________________________________________________________________________
Re: Pietenpol-List: Pacific Scientific T5 cable tensiometer
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerDo you think you could get close enough by calibrating it yourself? If it's for use on your Piet, you could suspend a known weight from a piece of 3/32 cable, to produce a known tension in the cable. My problem is I don't know anything about the required tensions in the various cables in the Piet. I havejust finished my wing panels and I guessed at the tension......Any suggestions?....Carl V.________________________________________________________________________________
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerCarl,No intention to barge in a discussion: On the subject of cable tensions I asked for and received next to nil when I started to complete my wings soooooooo I turned buckles, measured, turned buckles, measured some more until I thought they were tight enough to hold thething in shape then I proceded to tune the cables as you would the strings on abull fiddle or a Fender. I used the same procedure for the cabanne cables as well as the wing strut cables. It equalizes the tension more accurately than could ever be done with a tool. Couldn't use the same technic on the tail feathercables as they are 1/16 and the pitch would be too high for my hearing range as my highs went with WWII.Try it, it might work for you.Corky________________________________________________________________________________
Original Posted By: "John Ford"
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerSorry,I forgot to add that the sounds should be the same only on the cables of similiar lengths.Corky, beginning to not remember everything.________________________________________________________________________________Date: Sun, 27 Jul 2003 16:14:22 -0500
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerCorky...Your finger twanging tensiometer system sounds great, but does it still work when the wires are touching at the mid-point (or the 'button' spacers).and gee, Walt and Corky...Do you REALLY want to see the Fisherman? Don Hicks________________________________________________________________________________
Original Posted By: Waytogopiet(at)aol.com
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerJust pull the other cable out of the way so the cable will vibrate it's full amplitude.________________________________________________________________________________
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerIn a message dated 7/27/2003 6:27:20 PM Central Standard Time, Isablcorky(at)aol.com writes:> Just pull the other cable out of the way so the cable will vibrate it's > full > amplitude.> Of course Corky. Boy, I didn't think THAT one out !! Guess I'll pull the "buttons" off and try your method. Thanks Don________________________________________________________________________________Date: Sun, 27 Jul 2003 21:23:33 -0500
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerThanks for your comments, Corky. That's about what I've done too. The tensions may not be right, but they're close to even...Carl________________________________________________________________________________
Subject: Re: Pietenpol-List: Pacific Scientific T5 cable tensiometerMy "fergetter" works great. It's my "rememberer" that doesn't work so hot....Carl________________________________________________________________________________
Original Posted By: clif
Original Posted By: "DJ Vegh"
They are not available any more as I understand. I have attached theinstruction sheet which I transcribed from the factory original.Calibration is done by hanging a known weight on a cable and measuring tosee if the gage reads right. In the lid of the box is the conversion table.I can scan and get a copy to you if you need.Cy Galley, TC - Chair, Emergency Aircraft Repair, OshkoshEditor, EAA Safety Programscgalley(at)qcbc.org or experimenter(at)eaa.orgAlways looking for articles for the Experimenter----- Original Message -----
actually..... they are now being produced by a company calledOptimanufacuring.their site ishttp://optimanufacturing.com/they service and sell them.... I'll be sending mine in to them in a fewweeks.DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper----- Original Message -----
Original Posted By: Jim Ash
