Re: Pietenpol-List: Aircraft Spruce - custom made cables
Original Posted By: Jim Ash
to some extent I don't agree with that.... these cables are clearlyunairworthy. I understand custom made means no returns but that does notgiven them the right to send cables that are made so poorly that they won'teven meet the cables rated strength.It'd be like saying no returns on a custom cable even though the cable wasfrayed through 3 of the 7 strands of 19... no returns because it's custommade...You expect them to be made properly when you purchase them. You are in factpaying for a cable you can use not one you can't.Maybe I should post a picture or two of these cables...... seems like someof you aren't fully grasping the consequences if I were to use them. Ithink if you saw them first hand you'd understand how dumbfounded I am thatAS&S would even sell them to me.DJ VeghN74DVMesa, AZwww.imagedv.com/aircamper------------------------> You could look at it this way: Its $70 tuition towards your schooling.> Lessons learned. Custom made usually sold as-is, unless you get warrantyor the> like.________________________________________________________________________________Date: Wed, 03 Sep 2003 03:46:16 -0400
Original Posted By: dpilot
Jim,I am doing all my cables with swaged ends and fork fittings. More costly? yes,but I like the clean look is provides.DJ ----- Original Message -----
