Pietenpol-List: correct plans?
Original Posted By: "w b evans"
I'm just checking to see if I got a complete set of plans with the project I acquired a couple weeks ago. I know I need to order the supplemental plans for the long fuselage but I didn't want to also order the original plans unless I need to. This is the list of sheets I have along with the date on the title block:#1 - Fuselage details, 1-19-33#2 - Stabilizer and rudder details, 3-23-33#3 - Split axle landing gear, 1-25-34#4 - Dual control assembly, 2-26-34#5 - Wing details, 3-3-34#6 - Struts, tailskid, motor mount, 3-?-34#7 - Cowling and 3-view of plane, 3-20-34#8 - Model A conversion, (no date)There is also an additional, undated sheet showing the steel tube fuselage.Is this a complete set of the original plans? Also, in addition to the long fuse plans I would assume I should order the Builder's Manual and the 3-piece wing plans that the Piet family website sells. Is the Manual helpful and accurate?Thanks.________________________________________________________________________________
Re: Pietenpol-List: correct plans?
Original Posted By: dave rowe
