Pietenpol-List: Survey
Original Posted By: William Conway
I am putting together a survey on my website for people who are building, have built, or have flown a Pietenpol. I have several good questions on it so far, but are there questions any of you think should be on the survey? Heres what I have so far:Set of Plans Original 1929 Revised 1934 Grega Other Engine Ford Model-A Chevy Corvair Continental Ford Model-T Lycoming Ford V8 Franklin Kinner Velie Other Type of Fuselage Original Long Type Landing Gear Propellor Size & Material Instruments In Panel Airspeed Indicator Altimeter Compass Coolant Temperature Oil Temperature Other Guages:Type of Wheels Type of Wood Primarily Used Average Distance (ft.) T/O Landing Any others that should be on it? Once it's done, the results will be available to anyone who has a web browser.RichardWeb Developer, http://www.autoeurope.comHomepage: http://www.wrld.com/w3builder__________ ... __________
Pietenpol-List: RE: Survey
Great! This is just what I need! Thanks to John McNarry for some great suggestions, too.> How about these?> > Percent completed> Date started> Date completed> Registration #> Hours spent building> Cost> Primary source of materials> Tools found valuable> Finished weight> Location of CG.> How many inches back is your wing from vertical> Covering material> Paint type> Fuel tank location/size> Location/Home Field> Type of Glue used> General Comments> Fun Quotient (rating 1 to 10)> > STeve E.> > Web Developer, http://www.autoeurope.comHomepage: http://www.wrld.com/w3builder__________ ... __________
Pietenpol-List: Re: Survey
Original Posted By:> rdecosta(at)autoeurope.com (Richard DeCosta)
On Friday, January 23, 1998 4:37 AM, Richard DeCosta [SMTP:rdecosta(at)autoeurope.com]wrote:> I am putting together a survey on my website for people who are > building, have built, or have flown a Pietenpol. I have several good > questions on it so far, but are there questions any of you think > should be on the survey? Heres what I have so far:> > Set of Plans > Original 1929 Revised 1934> Grega Other > Engine > Ford Model-A> Chevy Corvair> Continental> Ford Model-T> Lycoming> Ford V8> Franklin> Kinner> Velie> Other > Type of Fuselage > Original> Long > Type Landing Gear > Propellor Size & Material > Instruments In Panel > Airspeed Indicator> Altimeter> Compass> Coolant Temperature> Oil Temperature> Other Guages:> Type of Wheels > Type of Wood Primarily Used > Average Distance (ft.) > T/O> Landing > > Any others that should be on it? Once it's done, the results will be > available to anyone who has a web browser.> > Richard> ----------------------------------------> Web Developer, http://www.autoeurope.com> Homepage: http://www.wrld.com/w3builderHow about these?Percent completedDate startedDate completedRegistration #Hours spent buildingCostPrimary source of materialsTools found valuableFinished weightLocation of CG.How many inches back is your wing from verticalCovering materialPaint typeFuel tank location/sizeLocation/Home FieldType of Glue usedGeneral CommentsFun Quotient (rating 1 to 10)STeve E.________________________________________________________________________________
Original Posted By:> > rdecosta(at)autoeurope.com (Richard DeCosta)
McNarry, John wrote:
Richard,How about:Doors?Cruise speed (level-no fair diving).Ted Brousseau>I am putting together a survey on my website for people who are >building, have built, or have flown a Pietenpol. I have several good >questions on it so far, but are there questions any of you think >should be on the survey? Heres what I have so far:>>________________________________________________________________________________
Original Posted By: "D.J.H."
Hi AllI just aquired an unfinished project. It is a Piet with 65 Cont.I would like to get in touch with anyone building or flying one in theSt. Louis area.Ken________________________________________________________________________________
Re: Pietenpol-List: Survey
Cliff,,, I got one too. Had the same concern. sounds legit though,,,,Carl----- Original Message -----
RE: Pietenpol-List: Survey
I received it but haven't replied yet.Jack -----Original Message-----
