Original Posted By: "Brants"
Subject: Pietenpol-List: Updated 'Infomation List'I've added all the suggestions, and here is the updated 'Information List.' I'm posting it again, to give everyone one more chance to add something to it. Speak now, or forever hold your peace !! I'll then send the 'Information List' to everyone that I have an e-mail for (builders and flyers), and they cancopy / paste to a return e-mail, fill in all the blanks as much as they can, and send it to me, or to the list. I'll also bring a dozen blank copies (is that enough blanks?) to Brodhead for anyone else that I missed. This should give us a pretty good data base, in a common format, on the specific constructionof our fleet of Pietenpols out there. Thanks to all who participate !!Chuck GantzerNX770CGI flew the past four days in a row (about a half hour after work), and it's the middle of January !! Yesterday, I took my buddy's wife up for a ride, andshe absolutely loved it !! Today at work, he said she talked about it all evening...she called her friends, her mom, and his mom to tell 'em about it !!Too Cool !!Here is the updated 'Information List': Aircraft Information:N Number -Name -Type -Short / Long fuse -Empty Weight - lbs.Gross Weight - lbs.Engine -Prop - XEmpty CG aft of Lead Edge - "Weight of Primary Pilot - lbs.Max Pax Weight - lbsInches wing tilted back - "Cabane strut length - "Cowling Material -Covering -Paint Process -Wheels -Tires -Brakes -Tailwheel -Bunji Chord / Springs -Seat Belt Harness -Survival Tools -Adhesives used: Ribs - Wing - Fuse -Fuel Capacity: Range - hrs. Wing Tank - gal. Material - Cowl Tank - gal. Material -Alterations : Fuselage Width - " Wingspan - ' " Engine Mount Length - " Fuselage Front Extension - Landing Gear Position - " Other -Wood type in various locations: Ribs - Rib Gussets - Spar Size - X Spar Material - Longerons - Longeron Gussets - Other -Steel type in various locations: Cabane Struts - Lift Struts - Landing Gear - Engine Mount Fittings - Fuselage Fittings - Firewall - Other -Airspeeds: Vr (rotation) Vx (best angle) - Vy (best rate) - Vne (never exceed) - Vs1 (stall) -Date first airplane noises / /Date of the first flight / /Address -e-mail - web site -builder(s)-________________________________________________________________________________
Re: Pietenpol-List: Updated 'Infomation List'
Original Posted By: "hjarrett"
Subject: Re: Pietenpol-List: Updated 'Infomation List'In a message dated 1/16/2004 11:37:44 PM Central Standard Time, Rcaprd(at)aol.com writes:and they can copy / paste to a return e-mail, fill in all the blanks as much as they can, and send it to me, or to the listChuck, Great Job! I'm not much on the cut and paste thing. If you would you post your mailing address I could then mail you the filled out form on NX920Y rather than clutter up the list. Thanx, Don Hicks________________________________________________________________________________
