Pietenpol-List: Control Horns
I am buiding the control horns for the rudder and elevators and notice that if I use an AN3 bolt and locknut to fasten the horn, the height of the nut is such that it will protrude into the fabric covering, although the bolt head should clear it OK.I am thinking of using an AN316 thin check nut and peining the bolt end over to stop it comeing loose, but would appreciate some advice.Many thanksRod WoollerChidlowAustraliaWishing you all a great time at Brodhead lProtect your inbox from harmful viruses with new ninemsn Premium. Go to http://ninemsn.com.au/premium/landing.a ... __________
Re: Pietenpol-List: Control Horns
Original Posted By: "rod wooller"
The hardware on the Monocoupe my buddy has was peened over at that verylocation.chris----- Original Message -----
