Pietenpol-List: Three piece wing spar dimensions
Re: Pietenpol-List: TACO Shirts and stickers
Terry, I need two tee shirts, both Large size, unless the shirts are smallerthan usual and in that case, one Xlarge and one Large. I also need twostickers. It looks great. DJ is right, in silk screening, the moreconsistently you can use the same color, the better. Over three differentcolors, just have them do a four color process. It will be cheaper in thelong run.Doyle----- Original Message -----
I am laying out a rib jig based on the Flying and Gliding plans but am planningon using the three piece wing. It appears from messages on the list that thethree piece wing may use a different size spar. What are the cross sectionaldimensions of the spar?________________________________________________________________________________
Re: Pietenpol-List: Three piece wing spar dimensions
Original Posted By: Jake Nichols
Jake,Same spar dimensions with either version.1" X 4 3/4" routed.An acceptable alternative is a 3/4" solid spar.Greg CardinalMinneapolis ----- Original Message -----
