Pietenpol-List: Pulleys
Subject: Pietenpol-List: PulleysWhich pulleys did you guys use on your torque tube? Is it best to use ball bearing type pulleys wherever possible? I noticed that the ball bearing 2" pulleys are .484" or more wide, 2 of those together is wider than the torque tube. The cheaper 2" phenolic pulleys with the bronze bushings that are specified as usable with 1/8" cable are also too wide at .438". (Am referencingpage 140 in the new AS catalog).Also read the archive discussion about the front torque tube elevator pully needing to be bigger than 2" based on 43.13 and what Bingelis says in his book (using 1/8" cable). Would their be any problem using a 3" ball bearing pulley there?ThanksRick Holland________________________________________________________________________________
Re: Pietenpol-List: Pulleys
Original Posted By: At7000ft(at)aol.com
I used the 2" ball bearing pulleys and yes 2 of them are wider then the torquetube so I put a jog in the pulley holding-on-tab thingies to make the gap 1".I also extended the tab down around the tube to get a little more weld area.Some people don't like the 2" up front but it seems to work. I used the 2".Chris TracySacramento, CA ----- Original Message -----
. . . and you put those bolts through the pulley brackets how?????????Gene ----- Original Message -----
I assume you wiggle them in at an angle through the bracket first then put the whole assembly into the holes in the spar.like a chinese puzzle.DJ Veghveghdesign.comMesa, AZ 602.743.5768"Where there's a will there's a Vegh"- ----- Original Message -----
nice!! very clean.DJ Veghveghdesign.comMesa, AZ 602.743.5768"Where there's a will there's a Vegh"- ----- Original Message -----
Pietenpol-List: Re: Pulleys
Very pretty work,only thing that would bother me is there is not really a braceto carry the side load as the cable pulls on them the way I see that.-I realizethere isn't a great deal ,but the pull would be at about a 45 degree angledown the length of the spar would it not? the drawings I have for the GN-1 havethe bracket built with 2 bolts and the strength runing parallel to the spar-horizontal.Iknow they need to lean some to align with the horn end but I wouldbe concerned if I didn't add some type of brace there.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Pulleys
Subject: Re: Pietenpol-List: Re: PulleysRaymond,These brackets look identical to mine, and I'm sure many many others, as they are per the 1933 BHP Hoopman plans. I'm sure these types of brackets haveperformed satisfactorily in the air for many years and hours. In this application, there is not a lot of side load to speak of, because you can onlytighten the aileron cables so much before everything binds up. Dan HelsperPoplar Grove, IL. Find out more about what's free from AOL at http://www.aol.com.________________________________________________________________________________
Original Posted By: "skellytownflyer"
Hi everybodyToday first day of spring it is possible to stand a raw egg on end. It is a good test and I know it can be done as I did it today.I better start Piet construction soon before I go completely off the deep end.Steve in Maine_________________________________________________________________Its tax season, make sure to follow these few simple tips http://articles.moneycentral.msn.com/Ta ... ___Subject: Pietenpol-List: Re: Pulleys
Original Posted By: Ryan Michalkiewicz
Well if it's not broke don't fix it I guess-thanks for the heads up.as you cantell I have not seen a set of original Piet plans and I have no doubt if theyhave been built for that long they have proved themselves.I had no intention ofstepping on anyones toes-just would rather be wrong than see anybody hurt.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 21 Mar 2007 17:27:16 -0700 (PDT)
Pietenpol-List: Piet in FL
Ryan;There are two Piet projects for sale in Huntsville, Alabama... 700 mi. from Lakeland. The nicer one is ready to mount a Ford Model A engine on it and the engine is part of the project. They are in the estate of our departed Pietenpoler Carl Vought. Information on the two projects is available at http://krnet.org/piet/Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net_________________________________________________________________i'm making a difference.Make every IM count for the cause of your choice. Join Now. ________________________________________________________________________________Date: Thu, 22 Mar 2007 08:26:19 -0400
Original Posted By: "Chris"
Hello Everyone, I read this forum everyday and it keeps me motivated in movingforward on building my piet. I am looking at getting the pulleys for the aileroncables. The plans call for 2 inch formica pulleys and 3/32 cable. I am lookingat ordering the pulleys from aircraft spruce part # A-123 (nas) it doesn'tshow any hub dia. or load limit (lbs). I was wondering if anyone could tell meif these pulleys are ok or have any other suggestions? Thanks Larry VRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Pulleys
Larry The A-123 series pulleys are used on secondary controls because the pulleyhas a plain bore. The MS24566 series are used on primary controls becausethey have a sealed ball bearing hub. I am using the MS24566-3B pulleysbecause I quite frankly didn't realize the aileron control cables were only3/32nd. If I would have known this I might have gone with the -2B andmodified the fitting. As it is I will just watch and see if it's a problemfor the 3/32 cable but I don't think it will be a problem. ChrisSacramento, CaWestcoastpiet.com-----Original Message-----
Original Posted By: "Robert Dewenter"
Chris. thanks for the information.Larry VRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
