Pietenpol-List: engine stand
Re: Pietenpol-List: Fuselage wedges on sides
If it calls for wedges, I would say use wedges.....otherwise it wouldn't call for wedges. :)Any particular reason for wanting to make two mitered cuts to fit the crossmembers instead of one?I believe in one of Tony B's books he gives examples of the various ways you could fit crossmembers when building wing ribs, and those principles would carry over to the fuselage. It doesn't so much matter how you fit the intersection of crossmembers and longerons. You gain no more strength from your double mitered joint on the right than is given by the plans fitment on the left, as zero strength is derived from the butt joints of crossmember-longeron-crossmember. All of the strength of that joint comes from the gussets tying everything together. The plans fitment requires only one mitered cut; multiply that out over all the pieces you have to fit and you'll save some time and hassle.As an aside, the plans fitment on the left appears to cover more surface area, but I would imagine that's because this is not an exact, scale representation of the joint/gusset....RyanOn Thu, Sep 3, 2009 at 6:38 AM, Michael Perez wrote:The plans call for wedges in certain locations on the sides of the fuselage. I have attached a picture of what the prints show and what I am doing. On the left of the vertical piece, the print shows the angled piece attaching as shown at the bottom. On the right of the vertical, the way I am cutting my pieces to fit. (Angle cut both sides of the piece to fit up against vertical piece.) -Cutting in this way, I wonder if the wedge is necessary?- Using the print sized 2-1/4" gussets, the wedge for "my side" of the drawing are very, very small.-(Having said all of this, I am using the wedges to fill the area under the gussets....just curious if it is required.)________________________________________________________________________________Date: Thu, 3 Sep 2009 08:53:00 -0700 (PDT)
RE: Pietenpol-List: landing like a Champ
All,I won't know till later today, but I may have found an entire garage kept 66 corvair, with 110 hp engine, for 400 bucks, and while I am still early in the building phase of my plane, I don't want to pass this up. Does anyone have drawings/plans/sketches for a corvair engine stand. My thoughts are to remove the engine and then rid myself of the car, so as to avoid undo yipping from the better half, put the engine on a stand and that way I can begin conversion, during construction down times. And yes I have ordered my conversion manual.Jake________________________________________________________________________________Date: Thu, 3 Sep 2009 08:38:26 -0700 (PDT)
RE: Pietenpol-List: Another sketch
Original Posted By: speedbrake(at)sbcglobal.net
Add the blocking to your diagram and highlight the glue lines. Now which has more glue surface and which joint has the larger thus stronger mass? I believe you will find that the origional does.Date: Thu=2C 3 Sep 2009 08:53:00 -0700
Re: Pietenpol-List: engine stand
Subject: Re: Pietenpol-List: engine standhere is the real question, if Bernerd had the resources to buy a liberty or a model A with all things being equal. What would he have used? An aircraft engine of a Model A engine?I do not discount the look, sound and feel and reliability of the Model A engine, however we are looking at the work of a forward thinking man who's only obvious constraint was cash, given the cash to purchase either (wwbb) What would Bernie buy?John**************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! =JulystepsfooterNO115)________________________________________________________________________________
Mikee wrote->Bernard used a Corvair in some of his Pietenpols>but check with Falcon Insurance, Avemco and such and>see if they will insure a homebuilt with a car engine.The Ford 'A' engine is straight out of a car. You meanthey won't insure Piets with Fords, either?>Of course some fly with no insurance...another risky thing to do.I admit it... I fly barefoot (uninsured). No lawrequires insurance and I think there are already toomany laws trying to protect us from lawsuits and lawyersanyway, not to mention insurance requirements. I know,I know... it is there to protect my widowed wife andall the innocent people I kill on the way into theground, not my sorry butt if something happens.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Thu, 3 Sep 2009 16:58:38 -0500Subject: Re: Pietenpol-List: engine stand
Pietenpol-List: Re: engine stand
Original Posted By: Jim
OK, folks here it is, the problem is I can't definitively ID the motor, Specs:1965 Corvair, says 500 on the fender, was licensed and driving through Jan of thisyear, when the owner lost their license. apparently "garage" kept meant untillast yearSee pictures: Car has 53596 miles, I was able to turn the drive pulley, the beltwas absent, so I gripped the main Harmonic balancer and turned it over a1/4 of a turn.it has 2 carbs, so it isn't a turbo, other than that I can't verify it's a 110HP.Any help would be greatly appreciated. I checked the everything bracket and couldn'tfind any numbershelpJake--------"Be who you are and say what you think, those that mind don't matter, andthose that matter don't mind" Dr. SeussRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/0903 ... ______Date: Fri, 4 Sep 2009 04:03:39 +0000 (GMT)
Re: Pietenpol-List: Re: engine stand
Subject: Re: Pietenpol-List: Re: engine stand
Original Posted By: "mr-fix-all"
Jake:Take a look here for Corvair engine IDhttp://www.corvaircraft.com/Michael in Maine----- Original Message -----
>> If it calls for wedges, I would say use wedges.....otherwise it wouldn't> call for wedges.
>> Any particular reason for wanting to make two mitered cuts to fit the> crossmembers instead of one?>> I believe in one of Tony B's books he gives examples of the various ways> you could fit crossmembers when building wing ribs, and those principles> would carry over to the fuselage. It doesn't so much matter how you fit the> intersection of crossmembers and longerons. You gain no more strength from> your double mitered joint on the right than is given by the plans fitment on> the left, as zero strength is derived from the butt joints of> crossmember-longeron-crossmember. All of the strength of that joint comes> from the gussets tying everything together. The plans fitment requires only> one mitered cut; multiply that out over all the pieces you have to fit and> you'll save some time and hassle.>> As an aside, the plans fitment on the left appears to cover more surface> area, but I would imagine that's because this is not an exact, scale> representation of the joint/gusset....>>> Ryan>>> On Thu, Sep 3, 2009 at 6:38 AM, Michael Perez > > wrote:>>> The plans call for wedges in certain locations on the sides of the>> fuselage. I have attached a picture of what the prints show and what I am>> doing. On the left of the vertical piece, the print shows the angled piece>> attaching as shown at the bottom. On the right of the vertical, the way I am>> cutting my pieces to fit. (Angle cut both sides of the piece to fit up>> against vertical piece.)>>>> Cutting in this way, I wonder if the wedge is necessary? Using the print>> sized 2-1/4" gussets, the wedge for "my side" of the drawing are very, very>> small.>>>> (Having said all of this, I am using the wedges to fill the area under the>> gussets....just curious if it is required.)>>>> *>> " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List> =nofollow>http://forums.matronics.com> blank rel=nofollow>http://www.matronics.com/contribution> *>> *>===========w.matronics.com/Navigator?Pietenpol-List======================com/contribution===========> *>>________________________________________________________________________________Date: Thu, 3 Sep 2009 12:27:46 -0500Subject: Re: Pietenpol-List: engine stand
