Pietenpol-List: Fuselage gusset plat
Hello All,Not being satisfied with the partially built fuselage I acquired I'mconstructing another. I have the side longerons, struts and bracescompleted. For the side gusset plates should I extend them above the topand bottom longerons 1/8 inch?Thanks!JackDSM ________________________________________________________________________________
RE: Pietenpol-List: Fuselage gusset plat
Jack,No. The turtledeck formers will hide any offset on the top, and both top andbottom longerons get filler strips between the gussets. Eventually, you willbe slightly rounding all off for a smooth transition around the corner forthe fabric. Besides, even if you do decide that you want the gussets tooverlap, you can do it with the spreader gussets overlapping the sidegussets.Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(16 ribs down.) _____
Original Posted By: Dan Yocum
