Original Posted By: "John Recine"
John I really like the laminated gear. Even the piece across the bottom! Your strutslook great too. I laminated my gear and all the struts. Took several hours.I couldn't resist sanding a spot to see what it was going to look like. Whatwoods did you use? And that angle finder/protracter in pic 4....I need tovisit you.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009Ribs and tailfeathers doneusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/lami ... ___Subject: Re: Pietenpol-List: Re: Okay I'll try it this way and see if it makesit on the boa
Original Posted By: Jerry Dotson
JerryThanks for the complements its nice to see that although I am building in a vacuum,the work is recognized. You as any other recognized builder are always welcome to visit my shop any time!And now with my newly installed metal detection equipment, no more missing tools.As like others of my fellow builders, I have other style points and additions bothinstalled and planned that I have not revealed. Which I may leave to revealat Brodhead in 2 years. Assuming I can stay on the grand plan if not then in 3 Brodheads! If anyone is interested I can put you in touch with my lamination furniture builderguy who laminated and shaped my white ash and black walnut gear and struts.The skill level and appearance are well beyond my equipment and skill level.John------Original Message------
