Pietenpol-List: Cabane struts
Re: Pietenpol-List: Cabane struts
Original Posted By: "Leon Stefan"
go here to see a section drawing of the large and small struts.http://www.sky-tek.com/struts.htmlI am using the small for the cabanes, large for the front lift struts andsmall for the rear lift struts.All in all, they cost me about $250 and that includes jury strut material.DJ VeghN74DVwww.raptoronline.comMesa, AZ----- Original Message -----
Original Posted By: "Dick and Marge Gillespie"
Subject: Pietenpol-List: Cabane strutsListers: I'm making my cabane struts now. You guys who have already madeyours, did you cap the ends or leave them open? (to moisture, gremlins,etc.) Thanks. Leon S.________________________________________________________________________________
Original Posted By: "DJ Vegh"
Subject: Pietenpol-List: Cabane strutsDJ: What is the wall thickness of your Carelson cabane struts? Are youusing the smaller size struts for your lift struts as well? If you areusing the larger size, what is the wall thickness of the larger struts?I listen to a am. radio talk show on WLS each morning . (if the skip isin the atmosphere) The general thought this morning is that Mayor Daleyis mentally ill. Leon S. Wondering if other mayors are thinking " ifDaley can do it, why can't I.________________________________________________________________________________
RE: Pietenpol-List: Cabane struts
et>My centersection is 36" wide and my cabanes atr vertical.- The fittings atthe top must be modified to allow the struts to be inset 3".Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
>My centersection is 36" wide and my cabanes atr vertical. The fittings atthe top must be modified to allow the struts to be inset 3".Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
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________________________________________________________________________________Subject: Pietenpol-List: Cabane struts
Pietenpol-List: Re: overbuilding a Pietenpol--some options
i'm still in the rib building stage, but was wondering, for those of you that havemade 36" (or wider) center sections- do the cabane struts remain upright ordo they angle out at the top?--------I may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: overbuilding a Pietenpol--some options
I've heard mention of a longer wing has that been done/successful?(been searching the archives)--------I may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 22 May 2010 07:51:04 -0700 (PDT)
Re: Pietenpol-List: Re: Mike's Cuy's DVD
Subject: Re: Pietenpol-List: Cabane struts
Here's a picture that shows the modification. The cabane strut fittingsattach to the spar fittings further inboard than the plans show.Jack PhillipsNX899JPRaleigh, NC _____
Pietenpol-List: Re: Cabane struts
My treasure trove of little know aeroplanes turned up this picture and a web sitethat enlightened me. It is worth a look. http://www.dieselpunks.org/profiles/blo ... dor-iiGood video Gary.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009Ribs and tailfeathers doneusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/curt ... ___Subject: Pietenpol-List: Re: Cabane struts
got it! thanks for the help guys!Earl--------I may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mike's Cuy's DVD
Original Posted By: Marshall Lumsden
Thanks guys...it was kind of what I was getting at.Now Mike Cuy...if you read this do you take Paypal by any chance? Im in Australiaand a draft is another $25 so its much easier if I add a few dollars more andpay you via Paypal if you can do that?Scotty--------ScottyTamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
