Pietenpol-List: Plans are here
just got mine Thursday- only took about a week--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Plans are here
Re: Pietenpol-List: Plans are here
Today was jackpot day! :o In the mail today, my plans came from Don Pietenpol,and my DVD from Mike Cuy came. Buster Brown brought the last of the books Ihad been waiting to get here from EAA. Like Christmas in June. :D :D :D Now all I need is an A&P job or some kind of job that will produce enough incometo pay bills, and buy wood. :o I put Mike's DVD in the computer (I haveWindows Vista on this one) and it started. It doesn't want to fast forward, orskip ahead when I ask it to. It will pause when I ask it to, so hopefully, Iwon't be limited to the DVD player to watch it. Another bonus for the day! :D--------Long flights, smooth air, and soft landings,GliderMike, aka Mike GlasgowRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Plans are here
Original Posted By: GliderMike
Congrats Mike! Jobs are over rated...all you need is a sign, "Will work for Poplar."Gary Boothe------Original Message------
Pietenpol-List: Re: Plans are here
Original Posted By: "bubbleboy"
Here's mine. The back is 7 1/2" tall and oval shapedto get the transition from TB to fuse sides more inline. The harness exit is even with my shoulders.Clif>My question is, is there any negative consequences to raising it an inch and a half? It looks better to me a little higher, and Ive seen some really raised.>> Also, I have all of my seat parts cut and I want to install them, but I'm > wondering about seat belt and shoulder harness locations. Front seat lap > belt is no problem, and I've found the discussions on the front seat and > rear seat shoulder harnesses, but I haven't found any pictures of where > the slots for the rear seat lap belt is located.________________________________________________________________________________Subject: Pietenpol-List: Re: Plans are here
Original Posted By: "Jack"
Mike...what program on your PC are you using to play Mike Cuys DVD? I have onebut cant play it on anything here. I have Vista and curious how you do it.ScottyAustralia--------ScottyTamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
The Prop I have is a 76 X 46 Sensenich and turns 2000 Plus , but the Prop thatis on the Funk powered Piet is a 76 X 44 and turns 2000 and a Sensenich Semitardesign and will pull the Piet at 85 with two people. That is where your propwith the proper flex will go into over drive when backed down on the throttle.My estimate or guess, you should cruise along nicely at 70 plus around 1800.Neat looking Piet Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Plans are here
Scotty, as best as I can tell, it looks like HP Quick Play--------Long flights, smooth air, and soft landings,GliderMike, aka Mike GlasgowRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Plans are here
Yep, you are right that it would be a convenient way to get started, but it wouldindeed start to add up. Your hobby shop may be more reasonable than mine. Most of the ones here are chainstores like Hobby Lobby or specialized hobby outlets (R/C aircraft). A goodselection, but given the quantity of materials we require, none of them offerthe best deal in wood products. I know that there are also marine outlets,but I have never compared selection or prices.bcharvet(at)bellsouth.net wrote:> I have a local hobby shop that has the 6 in x 12 in plywood that isn't too expensive,but I guess to make all the ribs it would really add up. Buying thesizes I used I could rip long pieces of gusset, then cut them to length with theband saw. I was only thinking that if money was real tight, you could at leastget started for a few bucks a week...--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
GliderMike wrote->I'm getting so desperate to build, I'm even considering>a possibility of going back to driving a truck.There's no need to drive trucks.If you have a set of plans and a lot of determination, you'reon your way. It's very simple to cruise the sawmills, usedbuilding materials yards, second-hand lumber yards, and just"sniff the air" to find lumber that you can use to start buildingyour Pietenpol airframe. Some big rough beams, or perhaps anold building that is being torn down, or a barn on a farm- all youneed are a couple of dry, fairly straight, rough timbers to yieldall the straight-grain lumber you'll need to build your airframe, ribs,tail feathers, and miscellaneous structure. Once you run themthrough a planer or jointer and then rip them to final dimensionon the table saw, you'll have more building stock than you needand you will have smelled some of the most wonderful wood smellsthat God has placed on this earth. All you'll need after that is alittle bit of glue and plenty of time in the shop and it will start to come together. I'll bet you can scrounge all your woodfor a few bucks, or for the price of your sweat to haul off someold wooden timbers. From there, it's all just fun and desire topull dimensioned structural shapes from big rough timbers.I love building with wood!Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net ________________________________________________________________________________Date: Tue, 8 Jun 2010 21:04:45 -0700 (PDT)
Pietenpol-List: Re: Ohio Piet gathering
Original Posted By: Dan Yocum
Where is this gathering?--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 09 Jun 2010 09:25:28 -0500
Re: Pietenpol-List: the mystery of the degrading tachometer reading
Original Posted By: "Dan Yocum"
Dan,Check the tach cable, if you haven't already. I had a tach cable break on N12939. After replacement, the tach reads higher. I changed nothing but the cable.Perry RhoadsN12939----- Original Message -----
Hey Shad,I'm still planning on showing up Friday evening, with one of the kiddos. I justmight take you up on that offer to use a tent and air mattress or hangar flooror whatever. I talked to Frank P. and he said he still doesn't have the Lambertback up and running, so he probably won't be making it. I'm looking forward to it! Who else is coming? Driving or flying?Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 9 Jun 2010 08:23:35 -0700 (PDT)
