Pietenpol-List: Fuselage Tips
Original Posted By: "bcolleran"
Jerry,I think you're on to something. If oil got in between the magnets, I bet some gunk got in the needle "bearing" area, too. That probably needs to be cleaned out.Ok, now Im not as worried as I was.Thanks again, everyone.Dan-- yocum(at)gmail.comOn Jun 10, 2010, at 6:09 PM, Jerry Dotson wrote:> >> Dan if the tach is steady...not bouncing around my $0.02 is either > the magnet is getting weak or the tach has internal friction. Wish > you were near I would loan you mine to test it. The needle is > removable and could have slipped. Not too likely.>> --------> Jerry Dotson> 59 Daniel Johnson Rd> Baker, FL 32531>> Started building NX510JD July, 2009> Ribs and tailfeathers done> using Lycoming O-235>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Fuselage Tips
Pietenpol-List: Re: Fuselage Tips
Original Posted By: "flea"
Hey guys I am getting ready tomorrow to start the fuselage. Any tips?Also what is the 21 1/2" Measurment for on the top right side?Thanks,BillN424BKRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ___Subject: Pietenpol-List: Re: Fuselage Tips
That thar would be a big ol gusset.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Fuselage Tips
Consider moving the top of the rear seatback back a couple inches, unlessyou like sitting at attention...wish I had.Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(18 ribs down.)-----Original Message-----
Re: Pietenpol-List: Fuselage Tips
Original Posted By: Ameet Savant
Subject: Re: Pietenpol-List: Fuselage Tips
its not the pass. inst. panel because on the drawing below it show the panel 15"back plus 6.25" back. thats 21.25". It's very close to the same location, buton the drawing asked about the 21.5" is showing the length of the dotted line,which is as we know a hidden detail. The only hidden details in this particulardrawing would be the gussets.Check out westcoastpiet.com for tons of high quality pics of high quality workon every single part of the plane if you haven't already done so. The only reasonI have not asked a ton of questions here is because pictures really are wortha thousand, in this case not only words but potentially dollars too.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Fuselage Tips
Jim,Check out http://pietenpol.cpc-world.com/images/I ... G.jpgLooks like the gusset along the fuse side for the Model A engine bay.CheersPeterWonthaggi Australiahttp://pietenpol.cpc-world.com-----Original Message-----
Original Posted By: "Jack"
thats the gusset I was talking about 21 and a half inches long. also a good exampleof the beautiful work I was talking about. Makes mine look like a kindergartenfinger painting project.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Bill it is the dimension for a 1/8 inch stiffener that goes on the inside ofthe frame. See it here on my site. http://textors.com/IMG_1816_640x427.jpg ... --Original Message-----
Original Posted By: "wayne(at)taildraggersinc.com"
Ben, I couldn't agree with you more on the seat back angle. Mr. Pietenpol must havefigured out in the previous airplanes he built that a more straight seat backangle was a good thing. I often find myself leaning a little off of the seatback to stay within the windshield better. Seldom do I find myself wanting tolean back. On landing the "at attention" angle is a very good thing. You suredon't want to be "at ease". Ha!Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 12 Jun 2010 11:18:16 -0400
Bill,I angled my rear seat back two inches, back one inch at the top and forwardone inch at the bottom, which keeps the balance closer to original. I hadanother fuselage which I didn't utilize where I could simulate manydifferent angles. Also, when it comes to gussets and blocks, stay close toplans. For example I added a block (shown in link) thinking it would helpthe strength and found out later it made the cutting and installation of theV braces on the front seat harder to do. I had to place them in front ofthe seat and wanted to position to the rear of the seat. You can see here...http://textors.com/IMG_1939_640x427.jpg . Many other shots atwww.textors.com.Enjoy,JackDSM-----Original Message-----
Re: Pietenpol-List: Re: Fuselage Tips
Being new to this, I've been reading every post. I have even started to go backand read most of the old posts. I am about to order plans and am counting onyou guys to help me out!--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 12 Jun 2010 15:37:42 -0600Subject: Re: Pietenpol-List: Re: Fuselage Tips
That's great news John, you came to the right place!JackDSM-----Original Message-----
