Pietenpol-List: Rust Protection Question
Original Posted By: Matthew VanDervort
Yet another question for my "list friends".With your wing/center struts,gear and various horns, how are you protecting against rust and corrosioninternally after painting? Prior to painting mine rust quickly if I don'tcoat with oil.Thanks,Jack ________________________________________________________________________________
Pietenpol-List: struts
I was planning on linseed oil but haven't done any "real" research yet but a few quick google searches have turned up promising resultsSent from my iPhoneOn Aug 18, 2010, at 8:56 PM, "Jack" wrote:> Yet another question for my =9Clist friends=9DWith your wing/center struts, gear and various horns, how are you protecting against rust and corrosion internally after painting? Prior to painting mine rust quickly if I don=99t coat with oil> > Thanks,> > Jack> > > > > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: struts
I don't know if anybody is needing a set but there is a set of BC12D struts I believeit said they are on Ebay aircraft parts list right now.I do not know thatthey are suitable for use to make Piet struts but I would sure check it outif I didn't already have mine made./on another note if anybody has any experiencehooking up a Datcon tachometer I'd sure appreciate a e-mail off list. I'mhaving some trouble figuring out how to program mine. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: RE: Pietenpol-List: remote mounting 0200 air box
Are you talking about the cowling? Those are Cleco's, holding the piecestogether until I could rivet them. Everything on the cowling is rivetedtogether.Jack PhillipsNX899JPRaleigh, NC _____
RE: Pietenpol-List: Re: Rust Protection Question
Thanks for the note Kevin, that's what I plan to do...JackDSM-----Original Message-----
Original Posted By: "Dan P"
Has anyone flying used a cork/rod type gauge successfully in their centersection tank? Was wondering if you can see it while strapped in.Thanks,JackDSM________________________________________________________________________________Subject: Pietenpol-List: Re: Rust Protection Question
Pietenpol-List: Re: Cork Fuel Guage
Bare metal. Epoxy primer before painting is hard to beat.--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Cork Fuel Guage
Original Posted By: Harvey Rule
My sight glass hangs down below the wing. I don't have a picture but I did findthis from flying-squirrel that is similar to mine. Easy to see while flying.--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/fuel ... __________
RE: Pietenpol-List: Cork Fuel Guage
Original Posted By: jack(at)textors.com
I have been using just such a gauge now for 5 years and I find it to be quite satisfactory. I would however suggest using a small tube in the gas cap to keep the rod from leaning over as mine does all the time.Someday I'm going to change that and fix it. I did measure and paint the end of the rod white to indicate when I am running low on fuel. I gave myself a few extra gallons before total empty. just to be on the safe side.You may want more.Just paint lower for more fuel at the end.
I've got one. Why would you have trouble seeing it?See it hanging down in front of the fornt cockpit windshield?Jack PhillipsNX899JPRaleigh, NC _____
Has anyone flying used a cork/rod type gauge successfully in their center section tank? Was wondering if you can see it while strapped in.Thanks=2CJackDSM ________________________________________________________________________________
