Pietenpol-List: Got an engine!
Pietenpol-List: Re: Got an engine!
I received my crankshaft back today from Moldex and picked up my case from a localtransmission shop after cleaning. Things are looking better!--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/clea ... ___Subject: Pietenpol-List: Re: Got an engine!
Re: Pietenpol-List: Sticker
Original Posted By: mike Hardaway
has anyone tried the half acetone half auto trans fluid home brew on those rustycylinders yet? it supposedly is as good or better than the penetrating oils.I never mixed the stuff up but it wouldn't cost a whole lot to have quite a bitof fluid to fill some cylinders.might be a place for it to be tried.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 17 Sep 2010 21:30:30 -0700Subject: Re: Pietenpol-List: Sticker
Tom - I'm pretty sure I built the gear per the plans and put the big tires on anyway.Out of all the gear problems I've had, that angle hasn't been an issue.Agree with Skip, no toe-in or toe-out. If you do err towards toe-out as Skipsays, you'll need really good springs/bungees to keep the gear from tryingto do the splits every time you roll forward. Again, straight as you can getthem.Split Axel Kevin--------Kevin PurteeNX899KPAustin/Georgetown, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Got an engine!
Original Posted By: "Kringle"
>> Just to throw another brand name in there, I swear by and have always > used "Mouse Oil." It is great stuff, the can stays wet because it > crawls up and out of the can, even sealed. How they hold those little > guys still to milk them is beyond me, though.>> Gene>________________________________________________________________________________Subject: Pietenpol-List: Re: Got an engine!
