Original Posted By: "Dave Sornborger"
Was wondering where others located their encoders. Close to transponder, orstatic source? My Trans-Cal manual says it should be as close as possibleto the altimeter. Since I'm mounting my transponder in the center section,I would rather run the static line down through the struts rather than thelarge wire bundle. Any thoughts?Thanks,JackDSM________________________________________________________________________________
Pietenpol-List: Encoder Installation
RE: Pietenpol-List: Encoder Installation
I put mine right next to the transponder, in the centersectionJack PhillipsNX899JPRaleigh, NC _____
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________________________________________________________________________________
