Pietenpol-List: Wood for landing gear
RE: Pietenpol-List: Wood for landing gear
Original Posted By:=0A=0A=0A=0A=0Aowner-pietenpol-list-server(at)matronics.com=0A[mailto:own
=0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0AMichael, =0A=0A - =0A=0AQuick question:- What are the dimensions of the stock you=0Ahave in hand? =0A=0A - =0A=0AGary Boothe =0A=0ACool, CA =0A=0APietenpol =0A=0AWW Corvair Conversion, Running =0A=0ATail done, Fuselage on gear =0A=0A21 ribs done =0A=0A -
Michael,Quick question: What are the dimensions of the stock you have in hand?Gary BootheCool, CAPietenpolWW Corvair Conversion, RunningTail done, Fuselage on gear21 ribs done
Pietenpol-List: Re: Wood for landing gear
>Nothing wrong with laminating.In fact, because smaller pieces of wood are used, the likelihood of hidden defects in the wood is lower. As long as the glue joint is as strong or stronger than the wood, the finished piece will be the same.You should make sure that the glue you use is waterproof, so regular Tite-Bond- isn't the best idea. But Tite-Bond III should be okay for this application - it IS waterproof.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... 1#315851le, List Admin.________________________________________________________________________________
You're in great shape! Just rip the boards to a little over 1" and laminateon edge! You'll just have more laminations.not a bad thing.Gary BootheCool, CAPietenpolWW Corvair Conversion, RunningTail done, Fuselage on gear21 ribs done
Nothing wrong with laminating.In fact, because smaller pieces of wood are used, the likelihood of hidden defectsin the wood is lower. As long as the glue joint is as strong or stronger thanthe wood, the finished piece will be the same.You should make sure that the glue you use is waterproof, so regular Tite-Bondisn't the best idea. But Tite-Bond III should be okay for this application -it IS waterproof.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 15 Oct 2010 09:45:01 -0700 (PDT)
I laminated mine out of =BC=94 planks of spruce, using resorcinol glue.Jack PhillipsNX899JPRaleigh, NC _____
To the nay sayers of nails.Have you ever wrecked a wood plane?Have you ever seenwhats left of an un nailed plane vs. a nailed plane?The glue doesn't come apartthe plywood delaminates,the nails do do something.They may not hold the planetogether but they will keep it from falling apart.--------Building a PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wood for landing gear
